Water Refraction fog desaturates when VrayDisplacementMod is ON
  • Water Refraction fog desaturates when VrayDisplacementMod is ON
    Hi , All
    is there anybody experiencing the same thing ?
    can please kindly help me with this.
    any help will be much appreciated, Thank you!
    i am using vray 3.40.01
    3ds max 2014
    here is my water without VrayDisplacementMod (look at the water) :
    and here is my water with VrayDisplacementMod on (and suddenly the fog is gone) :
    Here is my material for the water (sea) :
    and this is my VrayDisplacementMod parameters :
    best Regards,
    Dominique Laksmana
    How about you , Vlado ? any ideas ?
    Dominique Laksmana
      I don't think there is a issue here, the surface of the water is drastically changed and it is normal to have different appearance.
      In any case would it be possible to send us that scene for investigation? You can remove the building and any unnecessary objects but please keep the water,environment and lighting setup.
        Hi Svetlozar Draganov,
        thanks for the reply,
        i am sending the scene to support@chaosgroup.com now, and just for
        info, here is another try, VrayDisplacementMod=off (left side of image) and VrayDisplacementMod = on with 0 amount (right side of image)
        Dominique Laksmana
          With the displacement amount set to 0 it indeed looks weird and it is probably a bug.
          We'll investigate it and will keep you posted.
            This is a bug, its added it in our bug tracking system. We will keep you posted for any updates.
              Thanks a lot Zdravko
              Dominique Laksmana
                This issue has been fixed for the next official version of V-Ray.
