Invalid Bump Normal
    You should read the help page of the VRayMtlWrapper - https://docs.chaosgroup.com/display/...VRayMtlWrapper
    Which parts of the Standard materials are not properly translated by the converter ?
    Peter Matanov
    Chaos
      I am also getting those messages "Texture map (normal bump) is incompatible with Vray and may cause problems" after upgrading to VRay 3.4.03, Max 2017 and Win 10. Bug?
        No, it's not a bug and has nothing to do with 3.40.03.
        Originally posted by slizer View Post
        ... Only the warnings for using 3ds max Normal Maps which can be fixed by using the V-Ray scene converter (right click in the viewport).
        Peter Matanov
        Chaos
          Aha, thanks. I assume they render normally then.
            Would be better to convert them to VRayNormals actually, there is a one click solution(VRay Scene Converter) like Peter suggested.
            • #21
              hi,
              i`m getting the invalid bump normal on some multiscatter objects(i think). they`re using vraymaterials with noise + speckle bump maps and randomly going crazy. sometimes the bump mapping doesn`t even work, then rerender and it does. see image for lots of invalid bump normal warnings, 28000+ and not finished rendering.
              sometimes there are lots of errors, sometimes not. it`s most weird. happens on 3.40.03 and also 3.50.04. 3.50.04 can also suffer from significant lightcache slowdown randomly when using render region(in this scene), switch back to render full view and no slowdown. in 3.40.03 i just rendered a frame fine no errors, stopped hit render again and 1000`s of Invalid Bump Normal errors. it doesn`t seem to be a standard material issue ?
Name:	invalid bump normal.jpg
              a bit more testing..i`m using 3ds2017 for 2.50.04 and 3ds2016 for 3.40.03. it seems to happen in 2017/2.50.04 more than 2016/2.40.03 but since it`s rather random it`s difficult to be more accurate.
              thanks
              anthonyh
              • #22
                Have you run the vray scene converter?
                Set V-Ray class properties en masse with the VMC script
                Follow me for script updates: @ollyspolys
                • #23
                  hi olly,
                  i haven`t, i`ll try it but i don`t know what it will convert. the materials are already vray, light is a vray sun.
                  ...ok, just tried it and nope it`s still there and still random. render and no errors, render again and thousands of errors. weird.
                  thanks
                  anthony
                  • #24
                    the convertor does different things depending on what version of vray you are running - sorry I am not sure which version does what!
                    A recent-ish update converted normal maps to vray normal maps and that solved similar errors for us.
                    Sorry I can't be more help...
                    • #25
                      @anthony
                      A scene at peter.matanov@chaosgroup.com will be very helpful.
                      Peter Matanov
                      Chaos
                      • #26
                        hi peter, will do.
                        thanks
                        anthonyh
                        @olly, they`re bump maps, not normal maps. might be a reason ?.
                        cheers
                        anthonyh
                        @peter
                        scenes sent.
