Attempting to Bake the object in the attached scene crashes Vray 3.4 (Max 2016).
Crash on Texture baking
Hello,
In the attached scenes you are using CompleteMap - it is not supported and crashes. You should use VRayCompleteMap or the other V-Ray maps. There is an issue about that in our system - we should at least print a message that the Max maps are not supported.
Apart from that in the attached scene there is a bug - if motion blur is enabled RTT crashes. If you disable it - then there is no problem. We've logged this bug in our system.
YavorYavor Rubenov
V-Ray for 3ds Max developer
Originally posted by yavor.rubenov View PostIn the attached scenes you are using CompleteMap - it is not supported and crashes. You should use VRayCompleteMap or the other V-Ray maps. There is an issue about that in our system - we should at least print a message that the Max maps are not supported.
