Crash on Texture baking
  • Crash on Texture baking
    Attempting to Bake the object in the attached scene crashes Vray 3.4 (Max 2016).
    Gavin Greenwalt
    im.thatoneguy[at]gmail.com || Gavin[at]SFStudios.com
    Straightface Studios
    I tried merging the whole scene in again to do it that way and it still crashes.
    Gavin Greenwalt
      Oh nevermind, I tried a cube and it crashed to desktop. Apparently RTT is broken in 3.4/Max2016?
      Gavin Greenwalt
        In the attached scenes you are using CompleteMap - it is not supported and crashes. You should use VRayCompleteMap or the other V-Ray maps. There is an issue about that in our system - we should at least print a message that the Max maps are not supported.
        Apart from that in the attached scene there is a bug - if motion blur is enabled RTT crashes. If you disable it - then there is no problem. We've logged this bug in our system.
        Yavor
        Yavor Rubenov
        V-Ray for 3ds Max developer
          This bug is still present in V-Ray 3.60.04
