Exposure
  • Exposure
    I am having the hardest time exposing a scene. Usually, I use real work camera settings and turn lights up/down to work. My current scene is way too dark, almost black, and all I have is an HDRI and a V-Ray sun. If I tweak the exposure to look right, my white siding is point 4. I have to darken my siding until it is almost black. The same holds true when I try with just a V-Ray sun.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    white siding should have diffuse probably somewhere between 120 and 140 rgb in vraymtl. how are you doing your tonemapping?
    Marcin Piotrowski
    youtube
    CGI OCIO config 04
      In environment settings, switch to a different exposure control, then back to physical camera exposure control. I find sometime when you fiddle with the camera too much (even though you override it with the camera), the "link" between your cam and the exposure control gets lost. You either have to switch to something else, then back, or in the camera itself there will be an option that says "Install Exposure Control".
      Kind Regards,
      Morne
        It was too bright even for tone mapping. I'll try your color suggestion.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          I tried a new camera and it didn't change. I'll try toggling on/off the exposure.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            120 was the magic number. Odd... I have never had the problem before and I have done white siding. Anyway, thanks for the assistance.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
