bitmap blur 0.01 unexpected result ?
Apparently the issue is in the Bitmap node filtering. You can reproduce the same behavior with Scanline renderer.
To workaround the issue: Right click in the view-port and choose V-Ray Bitmap to VRayHDRI converter. This will switch the Bitmap nodes with VRayHDRI ones which have better filtering.
Originally posted by anthonyh View Posthi zdravko, weird. well changing the blur to 0.1 seemed to sort it as well. i`m not sure i`d want to convert all my bitmaps to use vrayhdri. but at least you found the culprit. thanks anthonyhAlessandro
