bitmap blur 0.01 unexpected result ?
  • bitmap blur 0.01 unexpected result ?
    hi,
    here`s a little thing i came across. bitmap blur set to 0.01 gave a strange corner patch which produced no bump. setting blur to 0.1 fixed it.
    it`s just a bump map. 2016/vray 3.40.03.
    thanks
    anthonyh
    Can you attach a scene?
      hi vlado,
      can do...actually i ought to send it to support email, it has a bitmap from turbosquid in it.
      cheers
      anthonyh
      sent.
        Apparently the issue is in the Bitmap node filtering. You can reproduce the same behavior with Scanline renderer.
        To workaround the issue: Right click in the view-port and choose V-Ray Bitmap to VRayHDRI converter. This will switch the Bitmap nodes with VRayHDRI ones which have better filtering.
          hi zdravko,
          weird. well changing the blur to 0.1 seemed to sort it as well. i`m not sure i`d want to convert all my bitmaps to use vrayhdri. but at least you found the culprit.
          thanks
          anthonyh
            Originally posted by anthonyh View Post
            hi zdravko, weird. well changing the blur to 0.1 seemed to sort it as well. i`m not sure i`d want to convert all my bitmaps to use vrayhdri. but at least you found the culprit. thanks anthonyh
            You don't need to convert any hdri; just use the loader with any filetype you have
            Alessandro
              As Zeronove said you don't need to convert your bump textures to HDRI ones. You just need to use VRayHDRI node to load whatever bump texture format you want. This won't affect the rendering performance or scene size.
