0.99 reflection problem with shadows
  • 0.99 reflection problem with shadows
    Got a dome with an hdr. Check my shadows on the reflections. Vray 3.40.03.
    Doesnt look normal i guess
    www.yellimages.com
    It's light cache being used for reflections. Although I never noticed it can be so obvious I always thought LC contribution in reflections is sort of gradually introduced as the reflection glossiness lowers
    Easy fix should be disabling usage of Light Cache for glossy reflections, but it's not really an efficient fix, as you lose a significant speed up gained by accelerating low glossiness with Light Cache data.
      Good to know that info. Ye it wouldnt be optimal to disable it. I hope for another fix thanks a lot!
      www.yellimages.com
        This is not a bug; it looks like something or someone has been tinkering with your material settings, in particular the "Treat glossy rays as GI" option in the VRayMtl material - it should be set to "Only for GI rays". For V-Ray 3.5 this option is hidden from the UI (it was meant for debug purposes only), but you can still set it to 1 from MaxScript (the name is "option_traceDiffuseAndGlossy").
          Weird, i didnt do anything still want me to upload that scene? ty
          www.yellimages.com
            Yep.
              https://www.dropbox.com/s/54syldp9r8...20bug.zip?dl=0
              there u go
              www.yellimages.com
                Thanks. It's because you've turned off the "retrace" option in the light cache. V-Ray even prints a warning about this. To fix this issue, either turn on the "retrace" option of the light cache, or as Recon442 suggested, turn off the "use light cache for glossy rays" option. I would recommend the first one (enable the "retrace" option - it's on by default too).
                  Thanks alot Vlado! ya i have it off by default on the very low settings i use so i render faster. Its nice to know all those small information though!!
                  www.yellimages.com
                    Oh, glad to know this is not something to be afraid of... I never ran into this probably because I don't mess with defaults that much
