Vray 3.5 Beta - Problem with VrayFastSSS2 material + Adaptive Lights
Aleksandar Mitov
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 3090 24GB + GPU Driver 566.14Tags: None
Sorry, I've enabled the light include list by mistake. Just go to the Exclude option of the lights and make sure the button Exclude is active, not Include.
Anyways, I tried Raytraced for the material and the issue still persists.Aleksandar Mitov
96GB DDR5
Originally posted by vlado View PostCan get me some more specific reproduction steps? It seems to work fine for me in a simple test.
VladoLast edited by Alex_M; 11-12-2016, 12:49 PM.Aleksandar Mitov
96GB DDR5
Now that the changelog of Beta 2 is released, I took a quick peek at it and found a couple of things that are still not working for me. One of them is the problem with VrayFastSSS2 materials and Adaptive lights. Maybe I'll have to check out the ALSurface material as a workaround for the time being as you suggested.
The image below is a test with Beta 2:
From the link above:
Originally posted by alexander.kazandzhiev View PostHello,
Here is the changelog:
Build 3.50.02 (beta) (11.01.2017)
Bug fixes:
(*) V-Ray: Artifacts with adaptive lights and VRayFastSSS2 material;
...Last edited by Alex_M; 14-01-2017, 07:17 PM.Aleksandar Mitov
96GB DDR5
The fix is applicable only for Raytraced scattering of the VRayFastSSS2. Try to avoid the prepass mode, it can lead to undesirable effects with the new algorithms.If it was that easy, it would have already been done
Peter Matanov
Chaos
Ok, got it. It does work fine with raytraced scattering. I'll try to remember to avoid prepass mode with Adaptive lights.
By the way, this particular scene has 150 lights and renders 3 times faster with Adaptive lights. Good job!Last edited by Alex_M; 16-01-2017, 03:22 AM.Aleksandar Mitov
96GB DDR5
