long render time with interior? look at this
  • long render time with interior? look at this
    for interior - dome light and longer time render or just portal light?
    dome light with vray sky in texture slot really make the longer time? or its just the curtain (2 side material) that make the trouble of 4 hours render! (light get scatter?) btw its brute force and light cache - image sampler - 1 - 50 / noise threshold 0.015.
    any tips to make the render fast and stay on brute force?
    It's the curtain alright. You have a few different options to tackle this. With portal lights you might exclude the curtain object from the lights. Or maybe tick off affect GI of the curtain object.
    A.
    www.digitaltwins.be
      even after i delete the curtain its want 10 hours to render this interior... i dont have any standard materials or strange import ... its a very clean scene...
      its all the dome light with sky map into him?
      i dont want regular sky and sun
        You can try to troubleshoot the scene. Put grey material on every object and see how fast it renders. You might have some raytrace materials which is bad. In this case you can use V-Ray scene converter to convert all non-vray materials to Vray ones.
        By the way, is Use local subdivs in Global DMC tab turned on? If it is and you're adjusting material and light subdivisions by hand, you might have used unnecessarily high subdivisions. If that's the case, try turning off Use local subdivs to allow Vray automatically deal with material and light subdivisions.
        Also, do you have a glass object in the windows? Try hiding the glass and see if it helps.
        What's the specs of the PC/PCs that you use for rendering this scene?
        Max 2023.2.2 + Vray 6 Update 2.1 ( 6.20.06 )
        AMD Ryzen 7950X 16-core | 64GB DDR5 RAM 6400 Mbps | MSI GeForce RTX 3090 Suprim X 24GB | GPU Driver 551.86 | NVMe SSD Samsung 980 Pro 1TB | Win 10 Pro x64 22H2
          No need to put VraySky into Dome light...use as is it
