Normally when I'm using Slate Material editor while IPR is running, wiring nodes update instantly in the mat. editor. However, the node wires of materials plugged in or unplugged from Multi/Sub-Object materials don't update while IPR is running. So for example if you've got a certain material plugged in Multi/Sub-Object and I unplug it while IPR is running, the IPR refreshes to show this change in the render but the wire still stays plugged in the Multi/Sub-Object material despite that it has been unplugged. Even after stopping IPR the wires' connection don't update. I hope this makes sense. If not, I can record a video.
Vray 3.5 Beta - Multi/Sub-Object node wires not updating while IPR is running
www.renarvisuals.com
office@renarvisuals.com
AMD Ryzen 9 9950X 16-core
96GB DDR5
GeForce RTX 5090 32GB + GPU Driver 572.83Tags: None
You're welcome! I think this problem might be linked to the other one I reported a month ago where running IPR and adjusting materials in the editor didn't update the map and material previews - http://forums.chaosgroup.com/showthr...IPR-is-runningAleksandar Mitov
96GB DDR5
