Clear Image when using Render mask
  • Clear Image when using Render mask
    Is there a way to tell VRay to clear up the vfb before rendering the next frame when using "selected" or "Object ID's" as a render mask? Or do i have to render out each frame by hand?
    The background is that i need to render out some additional masks, it works on a single image without problems but when rendering a sequence of images the framebuffer doesnt clears up after rendering so i always render on top of the old rendering which results in a bad alpha channel. Only workaround i found right now is to render each frame by hand and clean up the vfb instead of simply rendering a sequence...
    www.short-cuts.de
    In the Render Setup dialog, go to the Settings tab, switch the System rollout to Advanced mode and for the "Previous render" drop-down, select "Clear".
      Thanks! i knew there had to be a better way
      www.short-cuts.de
        I don't see that dropdown in 3.60.03 and I'm having this problem. Is this a bug or has it moved somewhere else?
          Hello,
          It is still there in the same place - https://docs.chaosgroup.com/display/...ncedParameters
          Yavor
          Yavor Rubenov
          V-Ray for 3ds Max developer
            I should have clarified...I'm on the RT side and don't see it.
              Ahaa I see. Unfortunately there is no such option in RT when used as a production renderer. We have it as an issue in our system.
              Yavor Rubenov
                Is there any work around? Right now I'm having to do a second render with a material override and multi-matte to get the object alpha I need.
                  Bump. I didn't find the "clear" option in Vray GPU. I can't render selected objects without all the frames appearing on top of each other. I think that is a very important option (in vray advanced it's the dropdown list that can be set to "unchanged" or "clear".) thanks
                    Unfortunately this is still not present.
                    I've written some kind of a workaround here:
                    https://forums.chaosgroup.com/forum/...32#post1032132
                    Yavor
                    Yavor Rubenov
                      Thanks looking forward to the feature being officially added, will use the workaround for the time being!
