I'm on the latest vray (3.50.03 afaik) and I used to use the lens effect source render element to determine how much intensity I should put my glare and bloom masks on. This seem to have disappeared?
Lens effects source render element?
Tags: None
I think there is just RGB color and effectsResult now in 3.5. Can't you just look at RGB color instead?
DanielDaniel Schmidt - Developer of psd-manager
Well I'm not sure, as I recall the values in the effect source element were different and helped determine which number to use as an intensity mask. Could someone in CG shed some light on this please?
Hello!
Originally posted by Vizioen View PostWell I'm not sure, as I recall the values in the effect source element were different and helped determine which number to use as an intensity mask. Could someone in CG shed some light on this please?
MargaritaMargarita Stoeva | chaos.com
Chaos QA (V-Ray for 3ds Max)
