weird render vray35003
Is this with Light cache? Can you check if you're using the new adaptive lights option? You can find it in the render setup window > VRay tab > Global switches (switch to advanced). Try switching it to full evaluation or uniform probabilistic. It will make your scene render slower, but it should work around your problem.
In any case, if it is possible, it would be extremely helpful to us if you could send us the scene.
We had an issue with adaptive lights in certain situations; this is fixed for the 3.50.04 update, but if you want a fix urgently, please email me to vlado@chaosgroup.com
VladoI only act like I know everything, Rogers.
Originally posted by samuel_bubat View PostLooks like we´re running into the same problem with one project. When will 3.50.04 be released ?
