3.5.03 Active Shade Resolution starts 640x360?
  • 3.5.03 Active Shade Resolution starts 640x360?
    So I set the res in max to 1280x720 for test renders and in RT CUDA production mode the VFB renders correctly to 1280x720.
    When I want to work with active shade, I set the res in max to 1280x720 and the VFB renders to 640x360. This only started showing up in 3.5.03 and later.
    Is there something I can do, other than dragging the VFB window to 1280x720 (which is not easy) to get active shade to start at the desired resolution?
    would love to know that too.
    I want to do a rendering bigger than my screen resolution
    Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
    www.AddYourLight.com
    Always looking to learn, become better and serve better.
      Hello,
      In 3.5 ActiveShade uses the size of the VFB for resolution.
      You can read some more about that here: http://forums.chaosgroup.com/showthr...e-for-Vray-3-5
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
        Originally posted by yavor.rubenov View Post
        Hello,
        Yavor
        I see that they will implement a switch to fix that. Having a 5000x6000px window on screen and still seeing the rest is...impossible and absurd
          Hello,
          Yavor
          Thanks, Yavor.
            Jason, in the build that I sent you, there is a "Fit to VFB" button for V-Ray RT ActiveShade, and "IPR options" section in the System tab for the regular V-Ray that control this behavior.
              Am I missing it?
                Hah, I must have sent you the build just before I added it, sorry
                  Oh, that's funny.
                    Is this in a nightly or only upon special request?
                      It's in a nightly build, but the 3.50.04 update is mostly done anyways - you'll get it fairly soon.
