3.5.04 - (same issue on 3.5.03) VrayStereoscopic helper enabled with adjust resolution, physical camera, camera type in vray settings set to spherical with override fov set to 360. When I render, the frame buffer shows the view for both eyes, and the image resolution is doubled per the 'adjust resolution' setting on the helper. However, the images being saved are mono. Frame buffer displays both eyes, but the actual file being saved to disk only shows one eye.
Thoughts?
Same results regardless if I used vray frame buffer or not. This worked fine in the past, not sure what I'm missing other than I have upgraded to Win10. Max 2017. I just reset and tried a blank scene to make sure it wasn't file specific, getting same results even without the camera override, stereoscopic helper doubles the frame size, if i save manually then WYSIWYG, but if I have Max save the file then it only saves half of it.
Thoughts?
