Sharp IES
Sharp IES
AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
2D | 3D | web | video
jiri.matys@gmail.com
https://gumroad.com/jirimatys
https://www.artstation.com/jiri_matys
https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
https://www.instagram.com/jiri.matys_cgi/
https://www.behance.net/Jiri_Matys
https://cz.linkedin.com/in/jiří-matys-195a41a0Tags: None
You could use an .ies designer to make your own ies file.
I used to do this but I read that lighting designers consider sharp artifacts like those in the image to be ugly. Apparently good quality downlights should have smooth transition between dark and light areas. This might explain why you most of the ies file you found are like this.Dan Brew
I have those. But its sharp only when I put it few cm from wall. Otherwise its really blurry.AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
Make my own IES with generator. I have this generator for a lot of years but never really use it Only some test and so on long time ago. So now I tried to achieve sharp and realistic result.
And thanks by the wayAMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
