vraysimbiontmtl with DarkTreeshader technoxray crashes
  • vraysimbiontmtl with DarkTreeshader technoxray crashes
    hi,
    any idea why this crashes vray with ... globalillummap::buildlightmap() error?
    can i do something against?
    using darktreeshader technoXRay.dsts
    thanks for help
    tomes
    using max2016 vray 3-40-02
    Dude, this stuff must be ancient. I have co-workers younger than this...
      xraymaterial from vray-materials.de... just wanted to test the look of it. but you`re right, its from 2009. but pay attention, child work is forbidden in germany
        Nope, he is 17 and our apprentice.
        Can you substitute the dark tree shader with a falloff and some noise for bump? Doesn't look to complex.
          thanks oliver,
          thought the whole information in the .dsts shader, opened in editor , is more complex than a falloff and a bump ?
          don?t know exactly how much of that is interpreted by vray...
          thanks anyway
          Shader 1 : DarkTree_Shader Color
          DarkData: 0, 0, 200
          Transform:
          Trans_0 : 1, 0, 0, 0
          Trans_1 : 0, 1, 0, 0
          Trans_2 : 0, 0, 1, 0
          Color:
          Light1_Color : 255, 255, 255
          Light1_Rise : 0.7
          Light1_Rotate : 0.85
          Light2_Color : 128, 128, 128
          Light2_Rise : 0.03
          Light2_Rotate : 0.15
          Surface_Color : Link_To 3 | Color
          Diffuse_Level : 0
          Diffuse_Function : 0.5
          Luminosity : 1
          Specular_Level : 0
          Specular_Function : 0.5
          Glossiness : 0.2
          Metal_Highlight : 0
          Anisotropy : 0
          Anisotropic_Direction : 0
          Reflectivity : 0
          Environment : 180, 180, 240
          Transparency : 0
          Refraction : 1.5
          Clear_Coat_Level : 0
          Clear_Coat_Glossiness : 0.4
          Clear_Coat_Thickness : 0
          Clear_Coat_Smoothing : 0
          Surface_Bump : Link_To 4 | Bump
          Alpha : Link_To 2 | Percent
          External 2 : Incident Percent
          DarkData: 1, 1, 200
          Transform:
          Common:
          Blend_Function : 0.5
          Pitch : 0
          Heading : 0
          Percent:
          Edge : 1
          Facing : Link_To 0 | Alpha
          External 3 : Incident Color
          DarkData: 1, -1, 200
          Transform:
          Common:
          Pitch : 0
          Heading : 0
          Color:
          Edge : Link_To 0 | Edge Color
          Facing : Link_To 0 | Face Color
          Natural 4 : Pumice Bump
          DarkData: 1, 0, 200
          Transform:
          Common:
          Pit_Depth : 0.5
          Lacunarity : 0.5
          Lacunarity_Lock : TRUE
          Roughness : 0.5
          Brightness : 0.5
          Contrast : 0.5
          Pit_Size : 0.25
          Density : 3
          Strata_Function : 0
          Blend_Function : 0
          Input_Seed : 1
          Bump:
          Pit : 0
          Background : 1
          Bump_Scale : 0.02
          Trigger_Bank: 1, 1
          Tweaker
          Tweak : IF_COLOR
          Tweak : Face Color
          Tweak : 0, 61, 127
          Tweak : IF_COLOR
          Tweak : Edge Color
          Tweak : 129, 237, 255
          Tweak : IF_PERCENT
          Tweak : Alpha
          Tweak : 0.3
            Seems to work fine with 3.50.04 - would you please update and see if there is any difference.
            If it still crashes would you please pack the scene and send/attach it for investigation?
              I managed to crash it, it occurs immediately when loading the .dsts file and gives the following error:
              Since those as discussed are way too old I don't know if this crash is going to be fixed at all.
              I'll make a note into the system but I'm afraid that SimbionMtl will be rather removed from UI than to be improved, unless it is easy fix.
                thanks for your work svetlozar, no problem...i have a good material
