VRayEdgeMod
  • VRayEdgeMod
    How can I get me edges to seam properly? Everything is welded.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    make it one smoothing group.
      No, that made things worse. No smoothing group looks the best, however, things are not seaming properly.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        usually displacement tears the edges at uv seam border. If you merge them together it should work fine, but you have to have supporting topology there to subdivide the mesh.
        Dmitry Vinnik
        Silhouette Images Inc.
        ShowReel:
          Also is it a texture map or a procedural map that drives your displacement, if it's a texture shouldn't you be better off with 2d displacement. And you should set a negative shift value of your displacement amount too.
          A.
          www.digitaltwins.be
            You need to make sure that the UVs are consistent in those places and then turn on the "keep continuity" option in the V-Ray displacement modifier.
              I did have keep continuity on; I don't recall having this issue in the past, I ended up fixing things in post.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Ok then; if you have time you can send me the scene so that I can check it out just in case.
