RT CUDA error 700
  • RT CUDA error 700
    Hello,
    2x Geforce 1070 Driver 378...
    Vray 3.50.04
    ./src/ocl_tracedevice.cpp(2114) : CUDA error 700
    ./src/ocl_tracedevice.cpp(1674) : CUDA error 1 : one or more of the parameters passed to the API call is not within an acceptable range of values
    Scene rendered with simple grey material override.
    Any idea how to solve this ?
    Kind regards
    Alex
    I'm also getting Error 700 with the nightly builds of Vray. With the latest stable version (3.50.04) I don't have this problem. Are you using a nightly by any chance?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Originally posted by Alex_M View Post
      I'm getting exactly the same error with the nightly builds of Vray. With the latest stable version (3.50.04) I don't have this problem. Are you using a nightly by any chance?
      Please try with 37X driver (more here).
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        Doh! It's even a sticky and I didn't pay attention to it! I confirm that this issue is now resolved for me by installing drivers 376.33.
        Aleksandar Mitov
        96GB DDR5
          Hello,
          the error appears with the driver version 178.92. Now I have just installed the 176.33 Version, but the error remains.
          I use vray 35004 27377 max2014 daily stable from 27 Apr
          Here are the available downloads, which of these would be best?
          Kind regards
          Alex
            Try with 378.49 and if that doesn't work, please send me the scene for investigation.
            Peter Matanov
            Chaos
              I've suddenly started getting error 700 again. It happens only in a particular scene if I add the Denoiser render element. I've just sent an email to support with the scene.
              UPDATE: It happens regardless of which render element I add.
              Aleksandar Mitov
              96GB DDR5
