Lens effects GPU accelerated failed
  • Lens effects GPU accelerated failed
    I am getting this error for first time while using lens effects:
    warning: [LensEffectsBase::applyBloomAccelerated] GPU accelerated bloom failed. | [LensEffectsGpu::gpuConvolveBatched] GPAPI is not initialized.
    warning: Error 1 during hardware accelerated lens effects calculation. Falling back to CPU. Applying lens effects might take longer than usual.
    How can I fix this error? Thanks!
    Best,
    Nikola
    1000 Skopje, Macedonia
    contact@narsov.com
    Mob. +389 71 382699
    www.narsov.com
    I fixed it. It was the graphic driver , I reinstalled and it works smooth now.
    contact@narsov.com
    Mob. +389 71 382699
    www.narsov.com
      Originally posted by narsov View Post
      I fixed it. I was the graphic driver , I reinstalled and it works smooth now.
      Nice, thanks for the update.
      Best,
      Blago.
      V-Ray fan.
      Looking busy around GPUs ...
      RTX ON
        Yeah, I am getting these all of a sudden. Latest NVIDIA from a couple days ago.
        Bobby Parker
        www.bobby-parker.com
        e-mail: info@bobby-parker.com
        phone: 2188206812
        My current hardware setup:
        • Ryzen 9 5900x CPU
        • 128gb Vengeance RGB Pro RAM
        • NVIDIA GeForce RTX 4090 X2
        • ​Windows 11 Pro
          Revert the driver?
          Peter Matanov
          Chaos
            I'm getting the same error as Bobby with Beta 2 when using lens fx. However, right after the GPAPI error appears the following line appears in the log - "GPAPI initialized successfully" and then every time I adjust the lens fx I get "Selected device: GeForce GTX 1080Ti" and also "Hardware accelerated glare/bloom completed.". So it seems to be working fine right after the error appears. I don't remember seeing this GPAPI error with the official 3.6 release. My GPU drivers version is 390.77. Is it fine to continue using them or should I install another version?
            Aleksandar Mitov
            www.renarvisuals.com
            office@renarvisuals.com
            AMD Ryzen 9 9950X 16-core
            96GB DDR5
            GeForce RTX 3090 24GB + GPU Driver 566.14
              Go back to 388 or update to 391. We have reports that 390 are not stable at all (for rendering and post effects).
              Peter Matanov
              Chaos
                Ok, will do. Thanks, Peter.
                Aleksandar Mitov
                96GB DDR5
                  Hi Everyone
                  I am so very new to V-ray and it seems that I bought the wrong laptop (see specification on picture attached) to be able to run it properly as I am getting the same error message: "Error 1 during hardware accelerated lens effect calculation. Falling back to CPU."
                  The quality of rendering I am getting is very hazy, even after I do post-production adjustments, use lighting, etc. (see next picture).
                  Can anyone help whether there are anythink I can buy to make my laptop perform better?
                  Thank you so much. Henrieta
Name:	V-Ray clarity - lack-of.png
Name:	Microsoft Surface Pro 9.png
