Light cache -- when set to Fly through it causes dark areas
  • Light cache -- when set to Fly through it causes dark areas
    I don't use Light Cache very often. I'm trying to precalculate one for a fly-through animation.
    I set it up to render one frame and set the mode to Flythrough. When I use the cache, I am getting these dark spots showing up on a low wall. They are rectangular or trapezoidal darker shapes -- not black just darker than the surrounding area. If I switch to Single frame mode, the dark areas go away.
    They don't seem to be based on any geometry -- there are no corresponding edges that follow these dark areas. I have tried dufferent Retrace settings and Subdivisions settings but it doesn't change them at all.
    Has anyone seen anything like this before?
    It's a known issue and we don't have a fix yet.
    Peter Matanov
    Chaos
      Is it only a problem when Adaptive Lights are used?
        In this particular setup - yes.
        Peter Matanov
        Chaos
          It makes little sense to use the fly-through mode in recent builds. The "retrace" and "leak prevention" options mostly deal with any flickering and the render time saved by the adaptive lights is often more than enough to compensate the calculation of the light cache for each frame. So the only parameter you have to deal with is the light cache subdivs, really.
          With that said, there are some changes in 3.6 that make rendering with the fly-through mode and adaptive lights enabled more consistent.
