Lens Effects: Crash to desktop on high res images
  • Lens Effects: Crash to desktop on high res images
    Just happened twice on two high res renders in around 12000px width while calculating the bloom and glare. I have the minidump for vray.exe and 3dsmax.
    Does this help?
    Hello?!?
    Really, this is anoying as hell.
      Too less V-Ram maybe? Have you tried to untick hardware accelerated?
      German guy, sorry for my English.
        128GB in my machine, when the GPU can't handle the effects it should fall back to CPU mode as far as I know.
          More details are needed - at least OS version, GPU types, CPU type, V-Ray version, drivers version and if the problem persist when the hardware accelerated option is off.
          Even though V-Ray does its best to fallback to CPU, if for example the drivers/OS/Max/etc are crashing, there is not much that we can do.
          Best,
          Blago.
          V-Ray fan.
          Looking busy around GPUs ...
          RTX ON
            Okay, here are the specs:
            OS: W7 Pro SP1
            GPU: GeForce GTX Titan 6gb, Dirver Version 382.33
            CPU: 2x Xeon 2687W, 3.1 Ghz
            Ram: 128gb
            Max: 2017, no SP
            V-Ray: 3.50.04 stable
            In the meantime, let me check if the problem occurs when hardware acc. is turned off.
              Oliver, Slightly off topic, but is there a reason you're not running the latest SP's for 2017 ? We're on to SP2 and whilst no guarantee it would fix or is even related to your problem, that was what caught my attention and might help ?
              Jez
              3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
              Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
              Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
              ---- Updated 06/09/23 -------
                When hardware acceleration is turned off, the render does not crash after finishing. Still, I would like to know whats going on and causes the issue.
                  If you have time and you can try few different drivers, it might be helpful. I would recommend trying the latest one 382.53 (http://www.nvidia.com/download/drive...x/119914/en-us) and if it fails, probably 376 (http://www.nvidia.com/download/drive...x/112200/en-us)
                  In the meaintime, we will try to reproduce it on our end ... Sorry for the troubles.
                  Best,
                  Blago.
                  V-Ray fan.
                  RTX ON
                    As I said, I have the dump file. If it helps for troubleshooting.
                      It still sounds like a driver problem, but having the dump file can be a start, yes.
                      Best,
                      Blago.
                      V-Ray fan.
                      RTX ON
                        I am having the same issue.
                        I am rendering 6x1 cube maps for VRs and they crash after they finish rendering which is not ideal when they take 4 hours to render!
                        My driver version is 372.90 but I will try the newer one to see if it solves the issue
                        Chris Jackson
                        Shiftmedia
                        www.shiftmedia.sydney
                          Dump files sent to Blago.
                            Tried this in 3.6 and with driver 376.09
                            So far no crashes, the lens effects are falling back to CPU mode because of missing VRAM. Will keep you updated if this really solved the problem.
                            • #15
                              Glad to hear it is getting better. Unfortunately, if there is crash is not in our code, often we can't do much to prevent it.
                              Best,
                              Blago.
                              V-Ray fan.
                              RTX ON
