We are using the newest Build for Vray 3ds max 2018. 3.60.01. I am running into a problem when i am using VRayMtlSelets. In the Exr the alpha of the material select is 50% grey. But in my frame buffer its correct it has the correct alpha. Also the alpha of the exr is and the other elements are correct.
VRayMtlSelect - half Alpha 3.6.01 3ds max 2018
I am not able to replicate that here. Would it be possible to send us a sample 3dsMax scene and render output from in for investigation?
Looking forward to hearing from you.Last edited by Svetlozar Draganov; 07-07-2017, 05:52 AM.
We had a bug with the alpha of VRayMtlSelect elements in the official 3.6 release, which will be fixed in the upcoming 3.60.02. In the meantime, if you need the fix, please email me to vlado@chaosgroup.com
VladoI only act like I know everything, Rogers.
