VRayMtlSelect - half Alpha 3.6.01 3ds max 2018
  • VRayMtlSelect - half Alpha 3.6.01 3ds max 2018
    We are using the newest Build for Vray 3ds max 2018. 3.60.01. I am running into a problem when i am using VRayMtlSelets. In the Exr the alpha of the material select is 50% grey. But in my frame buffer its correct it has the correct alpha. Also the alpha of the exr is and the other elements are correct.
    john nelson
    jnvfx.com
    CG Supervisor at Picture Shop LA
    I am not able to replicate that here. Would it be possible to send us a sample 3dsMax scene and render output from in for investigation?
    Looking forward to hearing from you.
      We had a bug with the alpha of VRayMtlSelect elements in the official 3.6 release, which will be fixed in the upcoming 3.60.02. In the meantime, if you need the fix, please email me to vlado@chaosgroup.com
        Sorry to dig up an old post on a slighty different topic.. My VrayMtlSelect not working at all in Max 2018 Vray 3.60.03. Works fine in latest version for Maya.
        CGI Artist @ Staud Studios
          Then we'll need the scene...
