task manager " no response" when clicking into vray window while rendering
  • task manager " no response" when clicking into vray window while rendering
    hi,
    i have here a problem with one machine.
    if i render locally and click onto a open window (vray-messages-vrayframebuffer-rendering window) i get a no-responce of one or all open windows and rendering hangs.
    if i only go over the vrayframebuffer with the mouse, it changes the rendering bucket position, so everything is okai, but if i click into the window it hangs.
    i tested this on another workstation and all is ok.
    i did a restart of my windows, i did a new install of vray 3-60-01
    running 3dsmax 2018 update1
    any ideas where to check what?
    thanks
    thomes
    Could you try to do the following tests and then give us feedback with your results:
    - Trun off Multi-threading option(Customize>Preferences>Rendering) and see if the issue is still present.
    - Try installing the latest available V-Ray and check for the issue again.
    Nikolay Kusht | chaos.com
    Team Lead, 3D Support | contact us
      multithreading "off" did the trick. thanks nikolay
        hello nicolay, is this fixed in a new update, as we would go "back" to 2018 again
          Rendering with 15% processor ... Sure it doesn't hangs
            Unfortunately this might not be V-Ray related and at this point you could render with low-thread priority or try using only one core on the machine that is more likely to become unresponsive.
