Multiscatter Light cache problem
  • Multiscatter Light cache problem
    Hi i have a exterior animation scene with multiscatter tree, i don't why light cache is a taking age to calculate, any idea?
    i am using max 2016 + vray Adv 3.40.01
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    I forgot to put my scene polygon in here, the polygon amount is: 66,118,670, verts: 69,147,429
    Jackie Teh
      the guys from multiscatter suggests using bf+bf
      Surrealismo
      https://www.facebook.com/surrrealismo
        hi,
        it might be a weird material try vraysceneconverter ?
        or maybe the model is just slightly damaged, try a different tree and see if it`s any better ?
        also depends how much memory you have.
          BF+BF is kill for animation rendering
          Jackie Teh
            Originally posted by anthonyh View Post
            hi,
            I have right click + and do the vraysceneconverter, but no change..
            i will try new tree and see how is the result...
            i got 32GB RAM here...my pc spec is Intel(R) Xeon(R) CPU E5-1660 v4 @ 3.2GHz, graphic card is Nvidia GeForce CTX 1070
            Jackie Teh
              I try my scene with max 2014 and max 2017, it work ok...only max 2016 got light cache problem, any idea please?
              Jackie Teh
                ok, i have try make a new multiscatter and add back the old proxy tree, still the same..
                i have use the old multiscatter and add new proxy tree, still the same..
                i have try merge everything to a new blank 3ds max, still the same...
                any solution for this?
                Jackie Teh
                  hi,
                  you could try posting your scene and see if anyone else has the same issue or send it to vray support ? i don`t think anyone uses 3.40.01 any more though so it might not be a fair test ? i have 3.40.03 on 2016 and 3.60.02 on 2018 for testing/playing. i`m holding out for a few more fixes before upgrading the workstations though.
                    hi,
                    Ok, i will ask my admin permission to send the problem file to vray.
                    and i just install vray 3.60.03 today and uninstall it because of rendering problem
                    Jackie Teh
                      When you are sending us the scene please make sure to mention this thread. Also what sort of problems did you get with the 3.60.03 build?
                        About the vray 3.60.03, Alexander Kazandzhiev find out there is a BlackStorm.dlr installer in the problem pc, he ask me to remove the file. i will do it tomorrow when i get back to work.
                        bytheway, i got a saving question here, i use Vray denoiser, in the end of the render, which one should i save, the vray denoise or the effect result?
                        Jackie Teh
                          This will be up to you to decide. The effect result will include all effects like denoiser and lens effects (if used) plus the RGB. Where the VRayDenoiser channel will store the Denoiser and RGB alone.
                            i cannot archive he file, it said got too much of duplicated bitmap, any other way to archive the max file?
                            Jackie Teh
                              "The archiving tool will not process the scene due to the duplicate file references found in each unique material." this is from Autodesk site. You don't have to archive the max scene just uploaded as it is. Make sure to create a folder and let us know its name.
