Cryptomatte Workflow with Fusion
  • Cryptomatte Workflow with Fusion
    Hello everyone,
    I'm trying to understand how to make it work but I don't seem to be able to do it.
    First of, I use Fusion 9 with the latest version (as of 9 augustus) of the plugin and the sample image (provided on github) are working.
    Since I want to use it for animation I'm trying to use a workflow compatible with batch render.
    I saw in the doc I need to store all the info in a vrimg so in the batch render I didn't set an output path.
    I enabled the Vray Frame Buffer and tick the V-Ray raw image file. In the popup window I only ticked EXR/VRST/VRSM 32-bit output I suppose there is no incidence of this option since I save as a vrimg file.
    Once the render is done I convert the vrimg to exr with the utility.
    Here I tick Multipart output and click convert.
    Once in fusion I import the exr and set the format in VrayCryptomatte.
    Then I have the console error that seems to say there is no metadata for cryptomatte to be found.
    The exr can be downloaded here : http://cynaptek.com/files/crypto.zip
    I can provide the scene in private.
    What am I missing ?
    Gil Guminski
    cynaptek.com
    As far as I know for proper work of CryptoMatte render element the .exr file should be directly exported from V-Ray, exporting the file to .vrimg and then converting it to .exr with VRIMG to EXR tool may not work properly.
    I'll discuss that with our Devs and I or someone else from the team will post confirmation about that.
    Cryptomatte element from the attached .exr file doesn't work here as well, I tested it in Nuke and it didn't work.
      Alright, my bad.
      I re checked the documentation and now it's clear. I supposed to have to store a .vrimg to make it work but it says save as openexr.
      I do prefear this as I don't have to convert to openexr.
      The thing that would be cool is to be able to save the cryptomatte as separate channels and still make it work.
      I suppose this will be possible in the future.
      Thank you !
      Gil Guminski
      cynaptek.com
        This is one of it's current limitations, considering this is the first implementation I believe we will have some updates for the future versions.
