This maybe a dumb question, but here it goes anyway.
So there is a lot of things I don't need that the denoiser generates, which make large files. I'd like to be able to just save my effects result channel as my RGB channel when saving. Basically just throwing away everything used to compute the channel. I was hoping to be able to simply save a PNG as my final output.
Is this possible without having to save a VRIMG/exr? I have to save VRIMG using frame buffer to get the denoiser to even compute, then I have to extract the effects result channel I want.
I am basically just looking to avoid having a huge amount of files and channels that i have to extract and then throw away. I don't have unlimited space like larger studios and don't need huge files with tons of control on the way out.
In short, is it not possible to just save the effects result channel as the rgb channel... out to something simple like a PNG?
Also, does Denoiser not compute unless frame buffer is enabled?
