Select and Not Responding
  • Select and Not Responding
    I don't know if it is me or just the way it is, but things just don't respond smoothly. I use IPR in its default mode, for the most part. While the FB is rendering and I pick something in the VP and I get the Not Responding for 10+ seconds. Starting a render takes 30+ seconds and stop is about the same. These seconds add up quickly and it is a pain. Am I expecting too much or should this not be happening? I have WIndows 10, MAX 2017, and a 1080ti.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    It's heavily scene-dependant.
    I was importing some 100k splines in max today, and forget the 10 seconds, i was clicking and waiting upwards of 15 minutes, so number of nodes (call them objects if you wish) has a severe influence on the max UI.
    The long render start seems to point at a long loading phase (textures, referenced geometry, and so on), or perhaps a bad displacement setting in static mode.
    Ofc, hey, send a scene to Support if you think it's with V-Ray.
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      It's not a big scene and I am only talking seconds. Saving EXR's are taking several minutes. I just would expect to hit stop and the render stops or starting instantly too. I don't know, I am probably just being impatient.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
