Dome light creating artifacts
  • Dome light creating artifacts
    The dome light in my scene is creating nasty artifacts. I've deleted it and replaced it with another and the artifacts are still there. It happens in all the camera views around the same spot. There are no maps in the dome light. The scene was rendering fine before. Happens with both distributed rendering and rendering locally.
    Here are some of the render elements:
    RGB
    Dome Light
    GI
    AO
    Has anyone ever had this problem?
    Cool, does raising the secondary rays bias to 0.01 help?
    A.
    www.digitaltwins.be
      I can go back and give it a shot. I ended up resetting the .max scene and merged in everything from the original file including the render settings. Renders fine now ?\_(ツ)_/?
        So it just popped up again out of no where in this scene where I reset max and merged everything in. Turns out it's not just the IBL but all direct lighting. Raising the secondary ray bias to 0.01 didn't help.
        RGB
        Lighting.IBL
        Lighting.Plane
        GI
          I found this in the vray documentation. Sort of looks like the same artifact:
          https://docs.chaosgroup.com/display/...lobal+Switches
          Click image for larger version  Name:	Capture.JPG Views:	2 Size:	51.2 KB ID:	966083
          I can't find the '2 sided option' checkbox in the material though... am I looking right at it? [edit: found it, it's checked]
            Try to disable adaptive lights - set it to uniform probabilistic. It's present in Advanced mode of Global Switches rollout.
              That seems to be working, thank you!!
                Hello,
                What are your GI settings and what is your V-Ray version ?
                Yavor
                Yavor Rubenov
                V-Ray for 3ds Max developer
                  GI settings are Brute Force / Light Cache, default settings. Vray Adv 3.50.03
                    If you upgrade to 3.6, is the issue still there?
