Metaball + IPR = Freeze
  • Metaball + IPR = Freeze
    I have a scene with a PFlow event plugged into a V-Ray Metaball. Whenever I launch the IPR, it compiles geometry forever then hangs. Removing the Metaball object from the scene makes the IPR works normally again. Using V-Ray Adv (CPU).
    Check my blog
    Thanks for the feedback, I'll add a note about that into our system and will let you know when it is fixed.
      Same here (Vray 3.60.03).
      Any news about that?
        I found out why it happens, and I was looking at a few potential fixes. If any of them works, it will go into the first update for V-Ray Next and we'll also try to port it to the 3.6 stable builds.
          By the way - there is something wrong with VrayBlendMaterial applied to VrayMetaball object.
          Below comparison - geosphere and metaball with the same material.
            Mnietek2707 I can't reproduce this. Are you still using V-Ray 3.60.03?
            Miroslav Ivanov
            Chaos Cosmos
