I am testing a short animated sequence (just the camera moving). The things I am testing are the glare/bloom settings and the denoiser of animated frames. My sequence has rendered as a series of exr files (around 100MB each for a 1080p sequence, so by the file size alone, I am assuming that the exr file is holding all of the various render elements created by the denoiser and the lens effects). I need to save as EXR files as I need the denoiser tool to analyse and apply the denoise effect post render.
When I add the exr files to an After Effects comp, I am seeing only the RGB (i.e. no bloom/glare).
Equally, when I add the VRay Denoised exr files to an After Effects comp, I am also seeing only the RGB, without all the glare/bloom that I see in the vray framebuffer.
How do I 'instruct' After Effects to see the glare/bloom versions of my sequence?
