Rendering Blanks screen
  • Rendering Blanks screen
    Hi all,
    I don't know if my computer is dying but when I render, the screen freezes and then suddenly popped back in. Sometimes the screen freezes and goes black then the screen comes back as normal but the 3ds max view-ports a greyed out.
    I have a pretty good computer. Don't know why its happening. Have you guys had this problem?
    Ill keep testing but this seems to happen mostly in bucket rendering mode.
    Thanks
    Steve ~
    It could be this https://docs.microsoft.com/en-us/win...n-and-recovery
      https://forums.chaosgroup.com/forum/...-3-6-vfb-hangs
      https://forums.chaosgroup.com/forum/...hile-rendering
        Thanks guys. Man this is 1 problem solving activity after another. I set up distributed rendering but now my computers crash when I render.
        I hired a network rendering licence and purchased a computer for network rendering - it was hard to set up and then I discovered that there is no IPR support. Now when I use the production render button my computer has a heart attack.
        I want to specify exactly what is wrong so I can fix it.
        My computer even crashes when I use VRay benchmark.
          Have you looked at your event viewer?
          Bobby Parker
          www.bobby-parker.com
          e-mail: info@bobby-parker.com
          phone: 2188206812
          My current hardware setup:
          • Ryzen 9 5900x CPU
          • 128gb Vengeance RGB Pro RAM
          • NVIDIA GeForce RTX 4090 X2
          • ​Windows 11 Pro
            Hi bobby
            thanks for the reply
            may I ask, what is the event viewer ?
              The Windows Event Viewer.
              Bobby Parker
              phone: 2188206812
              • Ryzen 9 5900x CPU
              • ​Windows 11 Pro
                Thanks for pointing me to the Event Viewer. I'm just going to learn how to use it. I will run some tests.
                In the mean time, may I ask how do I make sure that when I do distributed rendering that the other computer has the files?
                Thanks again.
                  I stopped using DR years ago. I opted for one large machine with a ton of cores and a ton of RAM. I spent more time managing the servers than creating images.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    So - I have no crashes at all when I unchecked multi-threading on my workstation. My CPU works away at 17% while the slave works its ass off.
                    Im glad this completely stopped the crashes.
                    Now I just have to figure out a way to allow multi-threading, assigning an amount of cores so when I render the workstation CPU runs at about 75% load with the rest available to run the computer.
                      Should I ask Vlado to code up something like the Renderman render settings where you can assign how many threads? - I can make a product suggestion?
                      I figured out how to set a programmes affinity. Use Task Manager > Details > Right Click 3DS Max > Set Affinity.
                      Remove 2
                        Okay - Things are getting more under control
                        I would like Vray to implement some control over the amount of cores used in rendering. I don't know if disabling cores using Affinity will also make other tasks in 3ds max slower, like transferring the files to the slave render nodes for example.
                        Nooooow I have yet anooother problem ;(
                        Look at the artefacts in the buckets.
                          .I will try to get rid of these artefacts seen above. Then I will assess if DR it worth is after I get some successful renders going. For now it has been very painful and potentially pointless. If it does not work out I will ask Chaos for a refund for sure.
                          Thanks everyone for your help.
                            it looks like the gamma is different on your slave or something.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              It was a missing plugin not installed on the slave. So it works.
                              Thank you everyone for your help! Thank you Bobby.
                              Since I cannot afford a monster, I will save up for one. in the mean time I will test DR for maybe, 1 more week. Ill give it my best effort. Hopefully its viable.
