CUDA Error 700
  • CUDA Error 700
    Hi there,
    First of all, I know that im not writing in the right forum channel but it was the only channel where i was permitted to make a new post. I didn't get the "new post" button anywhere else. sorry about that. (feel free to move this topic to its right category )
    Well, my big problem is that I get this error while rendering in RT mode.
    Im running max 2018 latest version, Vray the latest version, and with a GTX 1080 TI graphics card.
    I have also updated the driver of the GPU this evening.
    Its all running on Windows 10
    Its so frustrating not being able to use all the power that I have in that GPU.
    Can you please please help me with this urgent problem?
    Thanks in advance!
    Hi !
    Try to downgrade to an older version of the driver, i.e. 376.33
    Alexandre
      Hi Alexandre
      Thanks for the advice
      For som reason when I try to install the driver you specified, it tries to install but eventually write, that the graphic driver could not find compatible hardware, do you know what could be the reason for that?
      Soren
        Seems like a driver issue. Try reinstalling with the latest driver (again), reboot and see if this helps.
        Does this error happen with any scene?
        Best,
        Blago.
        V-Ray fan.
        Looking busy around GPUs ...
        RTX ON
          Hi Blago
          I just installed the latest driver, No geforce experience and all that jazz, just plain driver, rebooted and tried again with same scene.
          Then it came up with the warnings you see on photo 1 and 2.
          Then I tested it on another but super simple scene and it came up with a different warning string. as you see on image 3.
          This is sooo weird...
          really hope you can help me out here...
          I have just tested my GPU with GPUz and its looks fine in all the specs.
            The warnings in the simple scene are not to worry - they just mention things from Adv that are not supported in GPU.
            It might be a V-Ray GPU bug. Can you send the scene so we can check it?
            Best,
            Blago.
            V-Ray fan.
            RTX ON
              Hi Blago
              Sure thing, what mailadresse should i send it too?
              Best
              Soren
                It will be the best if you can mail it to our QA Max team so they can check it. You can mail peter.matanov@chaosgroup.com and me blagovest.taskov@chaosgroup.com. It will be nice if you can add link to this thread in the mail. Thanks!
                Best,
                Blago.
                V-Ray fan.
                RTX ON
                  Hi Blago
                  I have now sendt both of you a archive file via wetransfer.
                  Really really hope you guys can help me out here
                  Best
                  Soren
                    Morning Blago
                    Just wanted to hear if you have had the time to have a look at the file I send you in a mail?
                    Best,
                    Soren
                      Originally posted by underdogmedia View Post
                      Morning Blago
                      Best,
                      Soren
                      We haven't. During weekends we have far less people in the office.
                      Best,
                      Blago.
                      V-Ray fan.
                      RTX ON
                        It's reproducible here, I've logged it in our bug tracking system.
                        Peter Matanov
                        Chaos
                          We found the bug and we have fixed it in the internal builds.
                          We will port the fix to the stable builds and update you here when such stable nightly is be available (will take a while).
                          Sorry for the troubles,
                          Best,
                          Blago.
                          V-Ray fan.
                          RTX ON
                            It's in the stable nightly.
                            Peter Matanov
                            Chaos
