Unhandled exception when trying to render large res (10kx5k) - Very urgent
  • Unhandled exception when trying to render large res (10kx5k) - Very urgent
    Getting a 3589 error when preparing server.
    It is a fairly large resolution with a fair bit of displacement (all 3d displacement).
    I have 64gb.
    Do I have to raise the vray edge distance to get this to work or is there some kind of setting I need to change ?
    Regards
    Steve
    My Portfolio
    Hello,
    Can you check the available memory when you start the render - maybe you are running out of RAM ?
    If that happens - raising edge length could help. Also if you turn OFF the static displacement option - then the displacement will be dynamic geometry and you can limit it. Rendering will be slower but memory should be enough.
    Another thing you can check - if you've added render elements that you don't need - at 10kx5k each element consumes quite some memory..
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Cheers. I'll try turning off the static displacement option. No render elements for this shot. I also converted some forest items to vrayproxies. Fingers crossed.
      Regards
      Steve
      My Portfolio
        So it manages to get through to rendering now which is great but now I'm getting continual errors: Invalid geometric normal (-0 -0 -0) for "Vraylight".
        Also, it was rendering now but even rendering the HDRI sky I've used as a light source was taking forever. Normally with the sky HDRI it zooms through it very quickly and only when rendering geometry does it slow down.
        Regards
        Steve
        My Portfolio
          Okay. I tried rendering again with no geometry. I'm using camera type: BOX by the way. I still displays the same error without any geometry in the scene!!??
          Also, the renderer seems to be rendering the black areas (very slowly) of the long/lat box render. Why is this ?
          Regards
          Steve
          My Portfolio
            This is a small grab of the render with no geometry. The circle inidicates where vray starts rendering very slowly...even with no geometry in the scene.
            Regards
            Steve
            My Portfolio
              So, when I switch back to default camera type the normals errors stop and the render is much quicker. My client requires this type of box lat/long render.
              Regards
              Steve
              My Portfolio
                This is a bug; we have a fix for it in the nightly builds and we can get you a build, but I'm not quite sure if it's usable. In any case, email me to vlado@chaosgroup.com and we'll figure something out.
                Or you can render a cube 6x1 camera and rearrange the views manually. Or just render the 6 views separately with a perspective camera with 90 degrees FoV and put the, together.
                  I had to render out a spherical and then convert it to long/lat in the end. Good to know it's a bug that has been sorted. Thanks
                  Regards
                  Steve
                  My Portfolio
