Downloaded new Benchmark 1.0.7...... and.......
  • Downloaded new Benchmark 1.0.7...... and.......
    ..... I had to press enter around 20 times to 'read' through the Eula Agreement ?
    ......then the Command Line Interface went ahead and tested both my CPU, then GPU, then immediately closed itself.......
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
    exact same experience here. not sure how to check my performance against the rest?
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
      Me too. Maybe I'll try again when I have a chance to read through instructions...assuming there are some.
      Kind Regards,
      Richard Birket
      http://www.blinkimage.com
        I just downloaded it, too and it seems there may be some kind of misunderstanding or mislabeling? It#s definitely commandline-only and not the GUI version as it was the last time. Or maybe one has to start the commandline version with a GUI parameter for ultimate confusion purposes?
        Software:
        Windows 7 Ultimate x64 SP1
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        Intel Core i7-4930K @ 3.40 GHz
        NVIDIA GeForce GTX 780 (4096MB RAM)
        64GB RAM
        DxDiag
          V-Ray Benchmarks, when used command-line, should be used with arguments according to your preferences. There are instructions in the docs - https://docs.chaosgroup.com/display/...mand-lineUsage
          Also - list of available options is presented with -help (or -h switch).
          Ivan Slavchev
          SysOps
          Chaos Group
            Weird problems you seem to have, guys, it works fine here !
            Nicolas Caplat
            www.intangibles.fr
              Sorry for the misconfusion! Currently default version is console one and we'll switch it to be GUI for Windows.
              You could download GUI version here: https://download.chaosgroup.com/down...alone-107-free
                Yeah. I was confused as hell. Extremely long ULA, test running, closed on its own, uhhh.. did I just install something?
                  Would love a more user friendly way to dump this to a logfile, just appending the date and time and benchmark.
                  Would be good to be able to note when slaves have software or hardware issues that crop up.
                  Right now if you upload the benchmark to Chaos you see fractions of a second, but I can't see that fine detail anytime else - is there a local logfile?
                  PS: using this currently to output to file:
                  C:\Apps\vraybench_1.0.7_win_x64-cli.exe --quiet --mode=cpu > C:\Apps\output.txt
                    hm, GUI version should not close by itself. In what moment it closes?
                      Here you could see more info about debugging:
                      https://forums.chaosgroup.com/forum/...343#post833343
                      Basically you need to add "-debug=2" option and expect a log file in "%TEMP%/V-Ray Benchmark" folder.
                        Hi Varosi,
                        thanks for that, doesn't seem to work for me:
                        C:\Apps>C:\Apps\vraybench_1.0.7_win_x64-cli.exe --debug=2 --mode=cpu
                        Installer debug log file:
                        C:\Users\x\AppData\Local\Temp\installer_debug_2018 _01_25_13_12.log
                        [V-Ray Benchmark 1.0.7]
                        Unknown command line arguments:
                        debug
