Negatively scaled lights shine from the back even with Double-sided disabled
  • Negatively scaled lights shine from the back even with Double-sided disabled
    I noticed some lights in a scene shining in both directions even though Double-sided was disabled. After some troubleshooting it turned out the lights had a scaling of -100 100 100 instead of 100 100 100. As soon as I made the scaling in all axes positive, the lights returned to normal. Is this to be expected? Software is Max 2018 + latest updates and Vray Next Beta 1.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Sounds like a bug to me. Given the circumstance is quite an edge case, I still think it should be fixed.
    Software:
    Windows 7 Ultimate x64 SP1
    3ds Max 2016 SP4
    V-Ray Adv 3.60.04
    Hardware:
    Intel Core i7-4930K @ 3.40 GHz
    NVIDIA GeForce GTX 780 (4096MB RAM)
    64GB RAM
    DxDiag
      It looks like a bug. Can you post a scene with this (d)effect?
        Sure, please see attached.
        Aleksandar Mitov
        96GB DDR5
          So it's a disc light - you should have mentioned that in the first place
          Peter Matanov
          Chaos
            Yes, sorry. I see it doesn't happen with plane lights. Is it possible to make discs behave like them? For room ceilings where lights are positioned symmetrically I often just do only one side and then I simply mirror them to save time.
            EDIT: I now found that the same happens with mirrored geometry and VrayLightMtl too. It starts shining both ways.
            Aleksandar Mitov
            96GB DDR5
