VRayDistanceTex - mismatch between position on material and positon on displacement modifier
  • VRayDistanceTex - mismatch between position on material and positon on displacement modifier
    I was thinking it might be useful to use VrayDistanceTex so it's visible in the viewport.
    However if you apply it as a map in the standard displacement modifier, it is offset from the object being used as the displacement reference.
    I can use it in the displacement map in the material, but I'd like to have it in the viewport as well.
    Is it a bug, or am I missing something?
    Thanks,
    Steve
    Hello,
    The standard Max displacement modifier is an object space modifier - meaning that Max applies it in objects space - as if the object is placed in (0,0,0). That is why the result is offset.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Hi Yavor,
      OK, thanks!
      - Steve
