vray hdri map viewport display
  • vray hdri map viewport display
    When setting up hdri for exterior lighting. I start with Vray HDRI map in Mat Editor. Set spherical mapping and instance into max environment. Then config viewport background to show environment. So far so good. When I adjust horizontal rotation to position the HDI it works but the performance is painfully slow. Lot's of lag, difficult to work with. If I click the rotation spinner once it takes about 4 seconds for the HDRI to move in the viewport. In tutorials I have watched this is done and the rotation is very smooth and instantaneous in the viewport. I have a decent video card and lots of ram. Can I change some setting to help this perform better? Do others have this same slow HDRI in viewport issue?
    mark f.
    openrangeimaging.com
    Max 2025.2 | Vray 6 update 2.1 | Win 10
    Core i7 6950 | GeForce RTX 2060 | 64 G RAM
    I haven't had to do this for a while, over a month, but yes, I had this exact same issue - too busy at the time to determine what was the cause, and thought it could have been due to an updated NVidia driver.
    Was in 3ds Max 2017 and V-Ray 3.60.04.
    Jez
    3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
    Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
    Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
    ---- Updated 06/09/23 -------
      just the way it is, I guess. I posted this on the AD forum last week. The only reply was to use MAX's sky system - duh, but I don't want to. I turn the environment off when I rotate.
      Bobby Parker
      www.bobby-parker.com
      e-mail: info@bobby-parker.com
      phone: 2188206812
      My current hardware setup:
      • Ryzen 9 5900x CPU
      • 128gb Vengeance RGB Pro RAM
      • NVIDIA GeForce RTX 4090 X2
      • ​Windows 11 Pro
        OK thanks to you both. It's helpful to know that it's not just a problem for me /my system. The various video tutorials show it rotating very smoothly. Including the one below:
        https://www.youtube.com/watch?v=_SAl...&feature=share
        I think I have had that same smooth control in the past. Now....not so good.
        mark f.
          Yeah, but not since MAX 2016.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I'm getting this exact same problem in 2018 now. You guy's still experiencing this issue?
              Lock HDRI to texture is a work around.
              Just rotate Domelight instead, although you cannot line up to a vray sun using this method.
                Problem remains in 2018
                mark f.
