When setting up hdri for exterior lighting. I start with Vray HDRI map in Mat Editor. Set spherical mapping and instance into max environment. Then config viewport background to show environment. So far so good. When I adjust horizontal rotation to position the HDI it works but the performance is painfully slow. Lot's of lag, difficult to work with. If I click the rotation spinner once it takes about 4 seconds for the HDRI to move in the viewport. In tutorials I have watched this is done and the rotation is very smooth and instantaneous in the viewport. I have a decent video card and lots of ram. Can I change some setting to help this perform better? Do others have this same slow HDRI in viewport issue?
vray hdri map viewport display
mark f.
openrangeimaging.com
Max 2025.2 | Vray 6 update 2.1 | Win 10
Core i7 6950 | GeForce RTX 2060 | 64 G RAMTags: None
- Likes 1
I haven't had to do this for a while, over a month, but yes, I had this exact same issue - too busy at the time to determine what was the cause, and thought it could have been due to an updated NVidia driver.
Was in 3ds Max 2017 and V-Ray 3.60.04.
Jez
3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
---- Updated 06/09/23 -------
just the way it is, I guess. I posted this on the AD forum last week. The only reply was to use MAX's sky system - duh, but I don't want to. I turn the environment off when I rotate.Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- ​Windows 11 Pro
OK thanks to you both. It's helpful to know that it's not just a problem for me /my system. The various video tutorials show it rotating very smoothly. Including the one below:
https://www.youtube.com/watch?v=_SAl...&feature=share
I think I have had that same smooth control in the past. Now....not so good.mark f.
Originally posted by OPEN_RANGE View PostOK thanks to you both. It's helpful to know that it's not just a problem for me /my system. The various video tutorials show it rotating very smoothly. Including the one below:
I think I have had that same smooth control in the past. Now....not so good.Bobby Parker
phone: 2188206812
- ​Windows 11 Pro
Problem remains in 2018mark f.
