noise map giving diferent output renders
  • noise map giving diferent output renders
    Hello!
    I have a problem with the noise map 3ds max node. When I render a simple noise map linked to the difuse channel I am getting different results when rendering with Vray.Rt (CPU) or Vray.Edu. It looks like it reads the procedural noise map in a diferent way depending of the render engine. It happens also in other channels of the material.
    I am using 3ds max 2018 and vray 3.6
    Can someone tell me what I am doing wrong? or what I am not understanding?
    thank you!
    This is actually normal, 3ds max noise map always renders differently in different render engines.
    If you want to achieve the same pattern I can recommend you to try V-Ray NEXT BETA and instead of 3ds max noise map use VRayPlginNodeTex and choose Plugin type TexNoise.
    Hristo Dimitrov | chaos.com
    Chaos Cosmos Representative | cosmos.chaos.com
      hristo.dimitrov
      Thank you very much!!
        hristo.dimitrov one last question, where do I find the "VRayPlginNodeTex" ??
        sorry, I am new in this )
          If the image is not enough self-explainable, just tell me and I will try to explain in more detail.
            The image is perfect, but I do not have that node "Vraypluginnodetex" on my Vray maps section in material editor, here leave you an image
            Can this be because I am using an educational licence??
            thank you!
              No, actually this is because like I said in my previous post, VRayPlginNodeTex can be found in V-Ray NEXT BETA. But I guess you still use V-Ray 3.6.
                What sorcery is this VRayPluginNodeTex? Is all that stuff included by default or do you have to install and have a license of the various VRay plugins for different engines and such?
                Software:
                Windows 7 Ultimate x64 SP1
                3ds Max 2016 SP4
                V-Ray Adv 3.60.04
                Hardware:
                Intel Core i7-4930K @ 3.40 GHz
                NVIDIA GeForce GTX 780 (4096MB RAM)
                64GB RAM
                DxDiag
