Originally posted by hoppergrass
View Post
V-Ray NEXT Interiors
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tbh glorybound i didnt reset anything. I could be completely wrong but try changing back to your old camera settings and adjust the lights back and render. I had a feeling that it was the camera settings. Its happened to me before where i got strange render times with certain camera settings.
- Likes 1
I had some issues this week, vray3.6, where I was using very low EV settings (1 or 2...) to have enough light in the image. Was using a HDRI domelight (pg skies), adding portals seemed to do f-all. Vray settings were standard BF/LC. Admittedly it was a deep building with relatively small windows so it was tough to balance the areas near the windows vs the deeper areas. That really caused a lot of noise issues. Ended up faking some soft general lighting with vray sfere's. Still wasn't great though. It was that bad in the dark parts with dark materials that the denoiser didn't even seem to do anything. Ended up rendering the problem shots with extra light and in post brought back dark areas from the original lighting from the tests shots.
Bobby did you setup your render slave box?Dmitry Vinnik
Silhouette Images Inc.
ShowReel:
Originally posted by Morbid Angel View PostBobby did you setup your render slave box?Bobby Parker
phone: 2188206812
- Windows 11 Pro
No, not yet. I put an ad on craigslist, but everyone flaked out on me. I spent some time and I thought I got it, but nope. I switched around some cables, turned off my Pixelbook's WIFI and plugged in the data cable and it worked, but when I brought my Pixelbook to my office and plugged it in, it didn't work. I'll spend some more time this weekend.
whats the issue with it?Dmitry Vinnik
ShowReel:
The house was roughed with CAT5 and RJ11's, so I had an electrician come out and test which CAT5 was for my office and swap out the cover for an RG45 and patch it into my router (garage). I don't know if he put the RJ45's on wrong or if something is wrong in the walls, but I am not getting a signal when I plug into it (office). I can plug straight into the ISP router (garage), so that is working, but when I plug my laptop into the wall in my office, I don't get a signal. I am about ready to put the Render Pro in the garage since I don't really need physical access to it.Last edited by glorybound; 09-06-2018, 09:09 AM.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I'll have to post the materials. 1/2 an hour grayscale still seems very long.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI'll have to post the materials. 1/2 an hour grayscale still seems very long.
The override is just a gray material without any reflection.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI started another interior today, which is really rather simple, and I am experiencing the same insane render times. I am zipping them up now and I will post, but I just wanted to see if it is just an issue here or if others are experiencing higher render times, too.
VladoI only act like I know everything, Rogers.
