The RenderGlobalContext::camToWorld and RenderGlobalContext::worldToCam matrix variables have changed in V-Ray 5 CPU. The translation part now is always 0,0,0.
As a workaround I can use RenderGlobalContext::GetViewParams()->affineTM in psd-manager in the future but I this is likely to be used in other plugins as the RPF issue shows.
Daniel
- I notice this in the RenderGlobalContex that is provided as notification parameter in the system notifications NOTIFY_POST_RENDERFRAME
- tested using V-Ray 5 Hotfix 2 CPU (5.00.06 build 30453) on max 2021
- tested both a standard 3ds max Free and a VRayPhysicalCamera
- V-Ray GPU translation row is correct (and all other matrix values are identical)!
- psd-manager 5 camera export. - as a result my PSD Camera import plugin in After Effects will position the camera always at 0,0,0.
- 3ds Max built-in RPF file export - as a result the After Effects built-in RPF Camera import will import the camera at location 0,0,0.
Daniel
