3dsmax 2013 unicode
  • 3dsmax 2013 unicode
    3dsmax 2013 uses unicode
    Why don't vray use unicode?
    MeshFile::init(const char *fname)
    sorry for my English
    Another question
    Is it possible to compile VRay plugins for previous 3ds max versions with VS2010?
    I have got several errors like
    meshes_s.lib(mesh_file.obj) : error LNK2001: unresolved external symbol "__declspec(dllimport) public: __cdecl std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >(char const *)" (__imp_??0?$basic_string@DU?$char_traits@D@std@@V? $allocator@D@2@@std@@QEAA@PEBD@Z)
      This is a limitation of the MAX SDK as well. You can use daffodil to target older VS versions from 2010. This does not support VS2008 tho, so that only works for Max 2009 and older.
      http://daffodil.codeplex.com/
      Kind Regards,
      Thorsten
        We do use Unicode; only we opted to keep the V-Ray core UTF-8 (char's) instead of UTF-16 (wchar's). The vrender_unicode.h header file includes macros for converting between the two.
        The fname string is a UTF-8 encoded Unicode string.
          Yes (we do this all the time here), however you need to include/link against the run-time libraries of the Visual Studio version with which the respective 3ds Max release was compiled.
            Interessting! Do you guys use installed versions of VS in order to do that, or is the respective PSDK sufficient?
              Yes, you need to have the older VS versions (at the very least, the include/lib files). The Platform SDK is not enough - it only contains the Windows headers and libraries, but not the standard C and C++ ones.
                Dang. Was affraid that would be the case. VS 2005 is pretty incredibly expensive if you can get it at all these days. But still needed for some stuff (Max 2008 / Nuke plugins).
                Regards,
                Thorsten
                  I believe the free VS 2005 Express version + Platform SDK could be used to compile 3ds Max 9/2008 plugins.
                  I compile all psd-manager versions from within VS 2010 using Daffodil (so also 3ds Max 9 + 2008 )
                  Daniel
                  Daniel Schmidt - Developer of psd-manager
                    Does the Express edition include the 64-bit compiler and libraries now? (It didn't last time I checked but that was a while ago.)
                      I think atleast back then the 64-bit compiler was in the Platform SDK. I'm not using the Express version myself.
                      Daniel
                        One day, we'll be using c# to do this stuff and it won't be nearly as godawful.
