lightcache bounces default value
  • lightcache bounces default value
    Hi, i am a new to maxscript, i have a question here, i cannot find the default value for this lightcache bounces in maxscript, hoping someone can tell me the default value, thank you.
    attached a jpeg image for your reference, it highlight in grey in the jpeg.
    I am using Vray Adv 2.40.04
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 1 [7.00.05 build 32872]
    Start a new max and then in the listener type:
    Code:
    renderers.current.lightcache_bounces
    and press enter
    This will return the current value. In my new scene it returned 100
    Kind Regards,
    Morne
      Or instead of starting a new max, you can just reset everything to default for the render settings. You do that like so:
      Code:
      renderers.current = vray()
      then run the one in my previous post and it will return the default (100 in my case again)
      Kind Regards,
      Morne
        Code:
        Mr Morne,
        thank you very much, it work!
        Could i set this value to more higher value, like 1000 or something? what is it about? why i cannot find it in the render scene dialog?
        sorry for too much question.
        Jackie Teh
          You don't really need to change that value; it's there for debugging purposes only.
            Hi Mr Vlado,
            ok, noted, thank you very much.
            Jackie Teh
