Autodesk Materail
  • Autodesk Materail
    I don't know, you would think it would be one of the first materials you could convert. Is there a reason why we can't convert them using V-Ray's material converter?
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    What is an "Autodesk Materail"?
    Which specific shader are you referring to?
    Lele
    emanuele.lecchi@chaos.com
    Disclaimer:
      Autodesk Materials, from a Revit model, for example.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        What do they come in as in Max?
        What's the class name for them if you dragged one into the material editor?
        Lele
        Disclaimer:
          They come in different flavors for example:
          Autodesk Glazing
          Autodesk Metal
          Autodesk Generic
          Autodesk Plastic/Vinyl
          A.
          www.digitaltwins.be
            and those are shader classes? may it be i don't see them because i didn't install some interoperability pack or the other?
            EDIT: indeed. google knew, thanks Ashley for the precise names, they helped.
            Lele
            Disclaimer:
              https://knowledge.autodesk.com/suppo...3975D-htm.html
              This should do it (to standard or physical material, and then with the V-Ray scene converter.)
              Lele
              Disclaimer:
                I use the universal material converter script, but I thought V-Ray would handle it. I paid $70 for the script. I'll try Autodesk's. Thanks.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  This request has come up many times in the past and quite I am rather surprised that you haven't heard of autodesk materials. Vray for Revit does this conversion automatically.
                  I have tweaked Max's scene converter to convert all types revit materials to standard materials, then I use the Vray scene converter to change them to Vray materials. I have a script that converts all BDRF's to GGX because they are set to Phong with the Vray scene converter.
                  Its a bit clunky but works. It would be nice if Vray could do all this in one step.
                    Oh don't get me wrong, i'd agree.
                    I didn't know they existed, but they are seemingly a backbone for some AD workflow.
                    Lele
                    Disclaimer:
                      correct and has been for many years, they are a hang over from when revit and max used mentalray as its render. They were also a pain to find in your scene with heaps of materials and multi-sub materials before the scene converter and the universal converter script. It was a manual process of trawling though every material until you found that one autodesk or pro-material. Many hours lost.
                      One more to add to this request is the convert "Autodesk Bitmaps" , "Audodesk Tile" , "Autodesk Noise" and every other "Autodesk map" type to either a standard (scanline compatible) or Vray equivalent.
                      this is from the last time I conversed with Vlado about this , https://forums.chaosgroup.com/forum/...nversion/page2
                      if this ever sees the light of day I'd be a very happy man
                        From that thread, it'd seem to me that the AD scene converter (ie. the one i linked above) should be able to convert AD materials into V-Ray ones.
                        Or am i wrong?
                        Lele
                        Disclaimer:
                          it was promised, but I could never make it work to convert directly to Vray.
                            Pretty pricey, however, it works for me all the time.
                            https://3dstudio.nl/webshop/product/...rial-converter
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
Name:	material converter.jpg
                              Unless I am missing something, Vray materials are not listed
