Vray Volume Light
  • Vray Volume Light
    i don't know if there is a way of doing this because its so basic and i cant believe its not there so am not sure maybe i don't know a way of doing it
    so if anyone can enlighten me would be much appreciated
    can i make a volume light on V-ray lights ?
    like the 3dsmax's very basic spot/direct lights volume light ? can i make a volume light that only affects specific V-ray light planes/discs ?
    or can the Vrayenvironmentfog have like exclude/include lights dialog helping us achieving this
    i tried to use the lights dialog of the vrayenvironment fog but something is off
    i attached a screenshot explaining the problem
    this is by far as much as i can get about this effect
    am using vray next update 1.1
    a similar question was asked here, however they used standard 3dsmax volume lights, as a workaround, but were asking if there were any plans to add a vray volume light effect.
    https://forums.chaosgroup.com/forum/...y-volume-light
      after some testing the problem is that VrayEnvironmentFog affect all lights and there is no way we can completely exclude any light (not only the dome light) from it
      the attached picture shows how the scene got really dark after using vray fog
      so i hope they fix it or give us the vray light volume fog option
        will there be any response from support ??
          So there's two things - one is the max volume fog is limited to the cone of light you put it in, the vray one is a volume that's filling the entire scene (up to your fog height). Since the vray fog has actual thickness, it can block light, similar to haze or smoke in the air. The second part of this is lighting your shot before you've got everything in there - you'll likely have to compensate for this new fog object that's blocking light in your scene by increasing the power of the dome light. You can try lowering your fog height so there's less of it to block light or make your fog distance much bigger so that the fog that is there is far thinner!
          Chaos don't tend to do unphysical things if possible so I'm not sure if they'd be inclined to add in fog that's only in the light volume and nowhere else in the shot. You could run your fog as a second pass and add in in comp which'd give you a bit more flexibility after.
            You can also add in env gizmos as well to limit it so specific areas. i struggled with this but learnt to up my exposure a few stops with heavy fog and add a vray atmosphere pass to add more in post easily.
              Well the vrayenvironmentfog has a lights dialog where you only add lights that want to affect fog particles thats doesn't sound very physical afterall
              and thats actually a good option that is very useful we are artists after all
              all i want is a way to completely exclude lights
              or have this already existing lights dialog work correctly
              if that is achieved a vray light volume fog will be easily achievable
ID:	1025343Click image for larger version
ID:	1025344 .............
                  vlado
                  please help us on this topic
                    support please
                      A month without official support, that's not good. It must have slipped through the cracks.
                      Bobby Parker
                      www.bobby-parker.com
                      e-mail: info@bobby-parker.com
                      phone: 2188206812
                      My current hardware setup:
                      • Ryzen 9 5900x CPU
                      • 128gb Vengeance RGB Pro RAM
                      • NVIDIA GeForce RTX 4090 X2
                      • ​Windows 11 Pro
                        nevermind...
                        Kind Regards,
                        Morne
                          this excluding a light from env fog actually works totally fine, lol......did you actually try it?
                          check the file.
                          https://www.dropbox.com/s/hp2mn2w4he...clude.max?dl=0
                            squintnic
                            its 3ds max 2019 version so i cant open it since i only have 2018
                            but i would like to mention that this problem i know multiple users that encountered it so i think you're missing something
                            Morne
                            i would like to understand why you see this post too negative ?!
                            • #15
                              Originally posted by Arch.Hany View Post
                              Morne
                              I meant I deleted MY comment, because it was too negative and off topic
                              Kind Regards,
                              Morne
