Make vray dome lights affect 3dsmax viewport lighting /rendering?
  • Make vray dome lights affect 3dsmax viewport lighting /rendering?
    Hi, Autodesk has been focusing a bit lately on the fact that their viewport is actually capable of doing some PBR rendering although it is a bit of work to set it up.
    https://www.youtube.com/watch?v=82hhg8Q1nus&t=174s
    However you need to use a 3dsmax skylight to make the environment light visible in the viewport, and I couldn't get it to display a V-ray sky. It would be cool if Vray domelights could affect the viewport the same way, and Vray sky was supported. Is this possible (am I missing something)? If not could it be implemented without too much hassle using 3dsmaxs current framework?
    It's on the list
    Peter Matanov
    Chaos
