A proper viewport display and missing abilities of texture baking are my most frequent problems with vray...
Viewport nearly always shows black textures or only grey shader. And working with IPR is no solution, it slows everything down and causes too often crashes, when working on nodes.
I hope this is on the road map?
I count three different threads here:
a) Viewport display of shaders
b) Texture baking issues
c) Slow and crashy IPR "when working on nodes".
You should start one thread for each topic in the appropriate section, properly expanding on what it is that doesn't work for you, or the lamentations will hardly be remembered, them being into the wrong thread and forum section.
Also, remember that support is there to help you, so do not hesitate to fire them an email describing what issues you face, and in case send them a scene to reproduce the crashes.
